Time Before: 0.00145 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00236 seconds
Time Before: 0.00253 seconds
Time After: 0.00266 seconds
Time Before: 0.00346 seconds
Time After: 0.00611 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00270 seconds
Time After: 0.00970 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01146 seconds
Time After: 0.01188 seconds
Time Before: 0.01434 seconds
Time After: 0.01562 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01088 seconds
Time After: 0.01578 seconds
Time Taken: 0.00490 seconds
Memory After: 2,261.703 KB
Time Before: 0.02071 seconds
Time After: 0.02086 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02273 seconds
Time After: 0.02396 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.025564908981323
Time Before: 0.02683 seconds
Time After: 0.02695 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.02892 seconds
Time After: 0.03035 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=143124'
Time Before: 0.04243 seconds
Time After: 0.04269 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.041565895080566 seconds with 9 queries, spending 0.0080840587615967 doing MySQL queries and 0.03348183631897 doing PHP things.
