Time Before: 0.00476 seconds
Time After: 0.00564 seconds
Time Taken: 0.00088 seconds
Time Before: 0.00570 seconds
Time After: 0.00617 seconds
Time Before: 0.00636 seconds
Time After: 0.00651 seconds
Time Before: 0.00736 seconds
Time After: 0.01005 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00661 seconds
Time After: 0.01360 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01550 seconds
Time After: 0.01590 seconds
Time Before: 0.01867 seconds
Time After: 0.01989 seconds
Time Before: 0.01481 seconds
Time After: 0.02011 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02878 seconds
Time After: 0.02893 seconds
Time Before: 0.03194 seconds
Time After: 0.03321 seconds
Time Before: 0.03733 seconds
Time After: 0.03748 seconds
Time Before: 0.04037 seconds
Time After: 0.04183 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=143127' WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.05535 seconds
Time After: 0.05568 seconds
