Time Before: 0.00740 seconds
Time After: 0.01087 seconds
Time Taken: 0.00347 seconds
Time Before: 0.01099 seconds
Time After: 0.01151 seconds
Time Before: 0.01176 seconds
Time After: 0.01189 seconds
Time Before: 0.01281 seconds
Time After: 0.01541 seconds
Time Taken: 0.00260 seconds
Time Before: 0.01198 seconds
Time After: 0.01931 seconds
Time Taken: 0.00733 seconds
Time Before: 0.02365 seconds
Time After: 0.02416 seconds
Time Before: 0.02775 seconds
Time After: 0.02942 seconds
Time Taken: 0.00167 seconds
Time Before: 0.02278 seconds
Time After: 0.02967 seconds
Time Taken: 0.00689 seconds
Time Before: 0.04575 seconds
Time After: 0.04588 seconds
Time Before: 0.05448 seconds
Time After: 0.05579 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.057924032211304
Time Before: 0.06421 seconds
Time After: 0.06441 seconds
Time Before: 0.06678 seconds
Time After: 0.06855 seconds
Time Taken: 0.00177 seconds
SET lastactivity = 1776534335, location = '/forums/private.php?do=newpm&explain=1&u=143130'
Time Before: 0.08369 seconds
Time After: 0.08406 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.082701921463013 seconds with 9 queries, spending 0.0092158317565918 doing MySQL queries and 0.073486089706421 doing PHP things.
