Time Before: 0.00331 seconds
Time After: 0.00521 seconds
Time Taken: 0.00190 seconds
Time Before: 0.00531 seconds
Time After: 0.00585 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00606 seconds
Time After: 0.00680 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00751 seconds
Time After: 0.01088 seconds
Time Taken: 0.00337 seconds
Time Before: 0.00685 seconds
Time After: 0.01490 seconds
Time Taken: 0.00805 seconds
Time Before: 0.01907 seconds
Time After: 0.01981 seconds
Time Before: 0.02209 seconds
Time After: 0.02334 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01799 seconds
Time After: 0.02356 seconds
Time Taken: 0.00556 seconds
Memory After: 2,261.703 KB
Time Before: 0.03337 seconds
Time After: 0.03353 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.03964 seconds
Time After: 0.04089 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.04598 seconds
Time After: 0.04622 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.04945 seconds
Time After: 0.05090 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=143147' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.06450 seconds
Time After: 0.06484 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
