Time Before: 0.00143 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00252 seconds
Time Before: 0.00273 seconds
Time After: 0.00285 seconds
Time Before: 0.00354 seconds
Time After: 0.00609 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00290 seconds
Time After: 0.00950 seconds
Time Taken: 0.00660 seconds
Time Before: 0.01154 seconds
Time After: 0.01201 seconds
Time Before: 0.01440 seconds
Time After: 0.01568 seconds
Time Before: 0.01088 seconds
Time After: 0.01585 seconds
Time Taken: 0.00497 seconds
Time Before: 0.02083 seconds
Time After: 0.02102 seconds
Time Before: 0.02319 seconds
Time After: 0.02446 seconds
Time Before: 0.02861 seconds
Time After: 0.02880 seconds
Time Before: 0.03157 seconds
Time After: 0.03303 seconds
UPDATE session SET lastactivity = 1789065004, location = '/forums/private.php?do=newpm&explain=1&u=143219' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05051 seconds
Time After: 0.05086 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
