Time Before: 0.01531 seconds
Time After: 0.02037 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02046 seconds
Time After: 0.02089 seconds
Time Before: 0.02111 seconds
Time After: 0.02125 seconds
Time Before: 0.02210 seconds
Time After: 0.02460 seconds
Time Taken: 0.00250 seconds
Time Before: 0.02132 seconds
Time After: 0.02865 seconds
Time Taken: 0.00733 seconds
Time Before: 0.03464 seconds
Time After: 0.03507 seconds
Time Before: 0.03856 seconds
Time After: 0.03978 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03390 seconds
Time After: 0.04002 seconds
Time Taken: 0.00611 seconds
Memory After: 2,261.703 KB
Time Before: 0.06569 seconds
Time After: 0.06583 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.07709 seconds
Time After: 0.07835 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.080487966537476
Time Before: 0.08500 seconds
Time After: 0.08517 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.08752 seconds
Time After: 0.08896 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=143221'
Time Before: 0.10703 seconds
Time After: 0.10737 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.10605883598328 seconds with 9 queries, spending 0.0080480575561523 doing MySQL queries and 0.098010778427124 doing PHP things.
