Time Before: 0.02536 seconds
Time After: 0.03306 seconds
Time Taken: 0.00770 seconds
Time Before: 0.03314 seconds
Time After: 0.03359 seconds
Time Before: 0.03384 seconds
Time After: 0.03396 seconds
Time Before: 0.03479 seconds
Time After: 0.03715 seconds
Time Taken: 0.00237 seconds
Time Before: 0.03404 seconds
Time After: 0.04110 seconds
Time Taken: 0.00706 seconds
Time Before: 0.05169 seconds
Time After: 0.05214 seconds
Time Before: 0.05477 seconds
Time After: 0.05660 seconds
Time Taken: 0.00182 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.05065 seconds
Time After: 0.05682 seconds
Time Taken: 0.00617 seconds
Memory After: 2,261.703 KB
Time Before: 0.09996 seconds
Time After: 0.10008 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.44636 seconds
Time After: 0.44887 seconds
Time Taken: 0.00251 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.45769 seconds
Time After: 0.45786 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.46034 seconds
Time After: 0.46187 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=143222', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.48075 seconds
Time After: 0.48103 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
