Time Before: 0.00134 seconds
Time After: 0.00184 seconds
Time Before: 0.00191 seconds
Time After: 0.00241 seconds
Time Before: 0.00265 seconds
Time After: 0.00280 seconds
Time Before: 0.00349 seconds
Time After: 0.00728 seconds
Time Taken: 0.00378 seconds
Time Before: 0.00285 seconds
Time After: 0.01065 seconds
Time Taken: 0.00780 seconds
Time Before: 0.01235 seconds
Time After: 0.01277 seconds
Time Before: 0.01591 seconds
Time After: 0.01719 seconds
Time Before: 0.01182 seconds
Time After: 0.01738 seconds
Time Taken: 0.00556 seconds
Time Before: 0.02262 seconds
Time After: 0.02295 seconds
Time Before: 0.02519 seconds
Time After: 0.02668 seconds
Time Before: 0.02970 seconds
Time After: 0.02991 seconds
Time Before: 0.03187 seconds
Time After: 0.03337 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=143326' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04560 seconds
Time After: 0.04587 seconds
