Time Before: 0.00207 seconds
Time After: 0.00271 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00282 seconds
Time After: 0.00344 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00369 seconds
Time After: 0.00380 seconds
Time Before: 0.00468 seconds
Time After: 0.00690 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00384 seconds
Time After: 0.01032 seconds
Time Taken: 0.00647 seconds
Time Before: 0.01207 seconds
Time After: 0.01231 seconds
Time Before: 0.01484 seconds
Time After: 0.01608 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01150 seconds
Time After: 0.01625 seconds
Time Taken: 0.00475 seconds
Memory After: 2,261.820 KB
Time Before: 0.02153 seconds
Time After: 0.02176 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02382 seconds
Time After: 0.02506 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.026663064956665
Time Before: 0.02795 seconds
Time After: 0.02813 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03006 seconds
Time After: 0.03154 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788973321, location = '/forums/private.php?do=newpm&explain=1&u=143334', badlocation = 1
Time Before: 0.04405 seconds
Time After: 0.04450 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.04305100440979 seconds with 9 queries, spending 0.0080001354217529 doing MySQL queries and 0.035050868988037 doing PHP things.
