Time Before: 0.00488 seconds
Time After: 0.00645 seconds
Time Taken: 0.00157 seconds
Time Before: 0.00652 seconds
Time After: 0.00691 seconds
Time Before: 0.00715 seconds
Time After: 0.00729 seconds
Time Before: 0.00799 seconds
Time After: 0.01066 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00734 seconds
Time After: 0.01403 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01702 seconds
Time After: 0.01748 seconds
Time Before: 0.01995 seconds
Time After: 0.02136 seconds
Time Before: 0.01642 seconds
Time After: 0.02154 seconds
Time Taken: 0.00512 seconds
Time Before: 0.03299 seconds
Time After: 0.03313 seconds
Time Before: 0.20229 seconds
Time After: 0.20354 seconds
Time Before: 0.20749 seconds
Time After: 0.20764 seconds
Time Before: 0.21066 seconds
Time After: 0.21214 seconds
UPDATE session SET lastactivity = 1776872001, location = '/forums/private.php?do=newpm&explain=1&u=143365', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.22672 seconds
Time After: 0.22702 seconds
