Time Before: 0.00701 seconds
Time After: 0.00887 seconds
Time Taken: 0.00186 seconds
Time Before: 0.00897 seconds
Time After: 0.00949 seconds
Time Before: 0.00978 seconds
Time After: 0.00995 seconds
Time Before: 0.01073 seconds
Time After: 0.01303 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01002 seconds
Time After: 0.01753 seconds
Time Taken: 0.00751 seconds
Time Before: 0.02158 seconds
Time After: 0.02181 seconds
Time Before: 0.02432 seconds
Time After: 0.02549 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02094 seconds
Time After: 0.02574 seconds
Time Taken: 0.00479 seconds
Time Before: 0.04210 seconds
Time After: 0.04225 seconds
Time Before: 0.13644 seconds
Time After: 0.13771 seconds
Time Before: 0.14193 seconds
Time After: 0.14209 seconds
Time Before: 0.14437 seconds
Time After: 0.14597 seconds
Time Taken: 0.00160 seconds
UPDATE session SET lastactivity = 1783083464, location = '/forums/private.php?do=newpm&explain=1&u=143377', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.16073 seconds
Time After: 0.16096 seconds
