Time Before: 0.00149 seconds
Time After: 0.00197 seconds
Time Before: 0.00204 seconds
Time After: 0.00255 seconds
Time Before: 0.00282 seconds
Time After: 0.00295 seconds
Time Before: 0.00383 seconds
Time After: 0.00642 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00303 seconds
Time After: 0.01058 seconds
Time Taken: 0.00755 seconds
Time Before: 0.01282 seconds
Time After: 0.01311 seconds
Time Before: 0.01558 seconds
Time After: 0.01681 seconds
Time Before: 0.01208 seconds
Time After: 0.01701 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02342 seconds
Time After: 0.02356 seconds
Time Before: 0.02578 seconds
Time After: 0.02700 seconds
End call of global.php: 0.029654026031494
Time Before: 0.03086 seconds
Time After: 0.03103 seconds
Time Before: 0.03372 seconds
Time After: 0.03518 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=143417', badlocation = 1
Time Before: 0.04949 seconds
Time After: 0.04976 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.048542022705078 seconds with 9 queries, spending 0.0080249309539795 doing MySQL queries and 0.040517091751099 doing PHP things.
