Time Before: 0.01470 seconds
Time After: 0.02046 seconds
Time Taken: 0.00576 seconds
Time Before: 0.02058 seconds
Time After: 0.02114 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02149 seconds
Time After: 0.02163 seconds
Time Before: 0.02249 seconds
Time After: 0.02698 seconds
Time Taken: 0.00449 seconds
Time Before: 0.02169 seconds
Time After: 0.03259 seconds
Time Taken: 0.01090 seconds
Time Before: 0.03952 seconds
Time After: 0.03993 seconds
Time Before: 0.04316 seconds
Time After: 0.04439 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03883 seconds
Time After: 0.04463 seconds
Time Taken: 0.00581 seconds
Memory After: 2,261.703 KB
Time Before: 0.07618 seconds
Time After: 0.07631 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.08781 seconds
Time After: 0.08903 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.10012 seconds
Time After: 0.10026 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10290 seconds
Time After: 0.10435 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=143445', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.12299 seconds
Time After: 0.12325 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
