Time Before: 0.00205 seconds
Time After: 0.00280 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00287 seconds
Time After: 0.00379 seconds
Time Taken: 0.00092 seconds
Time Before: 0.00405 seconds
Time After: 0.00425 seconds
Time Before: 0.00511 seconds
Time After: 0.00794 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00433 seconds
Time After: 0.01288 seconds
Time Taken: 0.00855 seconds
Time Before: 0.01462 seconds
Time After: 0.01499 seconds
Time Before: 0.01759 seconds
Time After: 0.01879 seconds
Time Before: 0.01405 seconds
Time After: 0.01896 seconds
Time Taken: 0.00491 seconds
Time Before: 0.02415 seconds
Time After: 0.02431 seconds
Time Before: 0.02657 seconds
Time After: 0.02788 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.029510974884033
Time Before: 0.03062 seconds
Time After: 0.03079 seconds
Time Before: 0.03276 seconds
Time After: 0.03419 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=14345'
Time Before: 0.04645 seconds
Time After: 0.04671 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.045547962188721 seconds with 9 queries, spending 0.0088520050048828 doing MySQL queries and 0.036695957183838 doing PHP things.
