Time Before: 0.01243 seconds
Time After: 0.01547 seconds
Time Taken: 0.00303 seconds
Time Before: 0.01554 seconds
Time After: 0.01593 seconds
Time Before: 0.01616 seconds
Time After: 0.01627 seconds
Time Before: 0.01710 seconds
Time After: 0.01933 seconds
Time Taken: 0.00222 seconds
Time Before: 0.01634 seconds
Time After: 0.02337 seconds
Time Taken: 0.00703 seconds
Time Before: 0.03033 seconds
Time After: 0.03072 seconds
Time Before: 0.03360 seconds
Time After: 0.03480 seconds
Time Before: 0.02963 seconds
Time After: 0.03501 seconds
Time Taken: 0.00538 seconds
Time Before: 0.05577 seconds
Time After: 0.05594 seconds
Time Before: 0.06625 seconds
Time After: 0.06749 seconds
End call of global.php: 0.069961071014404
Time Before: 0.07449 seconds
Time After: 0.07466 seconds
Time Before: 0.07710 seconds
Time After: 0.07852 seconds
SET lastactivity = 1785356672, location = '/forums/private.php?do=newpm&explain=1&u=143511'
Time Before: 0.09532 seconds
Time After: 0.09567 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.094272136688232 seconds with 9 queries, spending 0.0076477527618408 doing MySQL queries and 0.086624383926392 doing PHP things.
