Time Before: 0.00878 seconds
Time After: 0.01379 seconds
Time Taken: 0.00501 seconds
Time Before: 0.01388 seconds
Time After: 0.01437 seconds
Time Before: 0.01470 seconds
Time After: 0.01489 seconds
Time Before: 0.01557 seconds
Time After: 0.01891 seconds
Time Taken: 0.00334 seconds
Time Before: 0.01495 seconds
Time After: 0.02230 seconds
Time Taken: 0.00736 seconds
Time Before: 0.02759 seconds
Time After: 0.02797 seconds
Time Before: 0.03043 seconds
Time After: 0.03169 seconds
Time Before: 0.02694 seconds
Time After: 0.03193 seconds
Time Taken: 0.00499 seconds
Time Before: 0.05101 seconds
Time After: 0.05127 seconds
Time Before: 0.06329 seconds
Time After: 0.06530 seconds
Time Taken: 0.00201 seconds
End call of global.php: 0.067051887512207
Time Before: 0.06979 seconds
Time After: 0.06995 seconds
Time Before: 0.07195 seconds
Time After: 0.07342 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=143525', badlocation = 1
Time Before: 0.08776 seconds
Time After: 0.08802 seconds
Page generated in 0.0868239402771 seconds with 9 queries, spending 0.0098168849945068 doing MySQL queries and 0.077007055282593 doing PHP things.
