Time Before: 0.00138 seconds
Time After: 0.00187 seconds
Time Before: 0.00194 seconds
Time After: 0.00237 seconds
Time Before: 0.00263 seconds
Time After: 0.00277 seconds
Time Before: 0.00368 seconds
Time After: 0.00651 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00285 seconds
Time After: 0.01184 seconds
Time Taken: 0.00899 seconds
Time Before: 0.01393 seconds
Time After: 0.01430 seconds
Time Before: 0.01696 seconds
Time After: 0.01814 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01336 seconds
Time After: 0.01838 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02572 seconds
Time After: 0.02588 seconds
Time Before: 0.02829 seconds
Time After: 0.02959 seconds
End call of global.php: 0.032647132873535
Time Before: 0.03407 seconds
Time After: 0.03425 seconds
Time Before: 0.03743 seconds
Time After: 0.03899 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=14361'
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.05645 seconds
Time After: 0.05676 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.055175065994263 seconds with 9 queries, spending 0.0084598064422607 doing MySQL queries and 0.046715259552002 doing PHP things.
