Time Before: 0.00202 seconds
Time After: 0.00259 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00269 seconds
Time After: 0.00313 seconds
Time Before: 0.00336 seconds
Time After: 0.00353 seconds
Time Before: 0.00442 seconds
Time After: 0.00719 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00358 seconds
Time After: 0.01130 seconds
Time Taken: 0.00772 seconds
Time Before: 0.01316 seconds
Time After: 0.01359 seconds
Time Before: 0.01681 seconds
Time After: 0.01823 seconds
Time Before: 0.01247 seconds
Time After: 0.01846 seconds
Time Taken: 0.00599 seconds
Time Before: 0.02554 seconds
Time After: 0.02570 seconds
Time Before: 0.02785 seconds
Time After: 0.02912 seconds
End call of global.php: 0.031800985336304
Time Before: 0.03299 seconds
Time After: 0.03312 seconds
Time Before: 0.03587 seconds
Time After: 0.03734 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=143651', badlocation = 1
Time Before: 0.05125 seconds
Time After: 0.05152 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.050040006637573 seconds with 9 queries, spending 0.008530855178833 doing MySQL queries and 0.04150915145874 doing PHP things.
