Time Before: 0.01317 seconds
Time After: 0.01715 seconds
Time Taken: 0.00398 seconds
Time Before: 0.01724 seconds
Time After: 0.01763 seconds
Time Before: 0.01788 seconds
Time After: 0.01803 seconds
Time Before: 0.01889 seconds
Time After: 0.02112 seconds
Time Taken: 0.00223 seconds
Time Before: 0.01811 seconds
Time After: 0.02685 seconds
Time Taken: 0.00874 seconds
Time Before: 0.03346 seconds
Time After: 0.03389 seconds
Time Before: 0.03548 seconds
Time After: 0.03673 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03258 seconds
Time After: 0.03699 seconds
Time Taken: 0.00441 seconds
Memory After: 2,261.820 KB
Time Before: 0.05795 seconds
Time After: 0.05810 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.06853 seconds
Time After: 0.06979 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.071968078613281
Time Before: 0.07792 seconds
Time After: 0.07860 seconds
Time Taken: 0.00068 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08134 seconds
Time After: 0.08277 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788845753, location = '/forums/private.php?do=newpm&explain=1&u=143705'
Time Before: 0.10126 seconds
Time After: 0.10159 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.10018706321716 seconds with 9 queries, spending 0.0083029270172119 doing MySQL queries and 0.091884136199951 doing PHP things.
