Time Before: 0.02558 seconds
Time After: 0.03356 seconds
Time Taken: 0.00797 seconds
Time Before: 0.03367 seconds
Time After: 0.03418 seconds
Time Before: 0.03447 seconds
Time After: 0.03475 seconds
Time Before: 0.03545 seconds
Time After: 0.03809 seconds
Time Taken: 0.00264 seconds
Time Before: 0.03480 seconds
Time After: 0.04200 seconds
Time Taken: 0.00720 seconds
Time Before: 0.05093 seconds
Time After: 0.05133 seconds
Time Before: 0.05387 seconds
Time After: 0.05519 seconds
Time Taken: 0.00132 seconds
Time Before: 0.05031 seconds
Time After: 0.05543 seconds
Time Taken: 0.00512 seconds
Time Before: 0.09074 seconds
Time After: 0.09091 seconds
Time Before: 0.17354 seconds
Time After: 0.17483 seconds
Time Before: 0.18619 seconds
Time After: 0.18641 seconds
Time Before: 0.18881 seconds
Time After: 0.19036 seconds
Time Taken: 0.00156 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=143828' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.20783 seconds
Time After: 0.20811 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
