Time Before: 0.02601 seconds
Time After: 0.03055 seconds
Time Taken: 0.00454 seconds
Time Before: 0.03065 seconds
Time After: 0.03115 seconds
Time Before: 0.03142 seconds
Time After: 0.03171 seconds
Time Before: 0.03275 seconds
Time After: 0.03540 seconds
Time Taken: 0.00265 seconds
Time Before: 0.03179 seconds
Time After: 0.03943 seconds
Time Taken: 0.00764 seconds
Time Before: 0.04949 seconds
Time After: 0.04990 seconds
Time Before: 0.05318 seconds
Time After: 0.05442 seconds
Time Before: 0.04880 seconds
Time After: 0.05461 seconds
Time Taken: 0.00581 seconds
Time Before: 0.09928 seconds
Time After: 0.09942 seconds
Time Before: 0.11636 seconds
Time After: 0.11763 seconds
Time Before: 0.12692 seconds
Time After: 0.12710 seconds
Time Before: 0.12952 seconds
Time After: 0.13094 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=143837' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.14892 seconds
Time After: 0.14920 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
