Time Before: 0.00166 seconds
Time After: 0.00225 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00235 seconds
Time After: 0.00301 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00333 seconds
Time After: 0.00354 seconds
Time Before: 0.00422 seconds
Time After: 0.00679 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00359 seconds
Time After: 0.01046 seconds
Time Taken: 0.00687 seconds
Time Before: 0.01225 seconds
Time After: 0.01265 seconds
Time Before: 0.01500 seconds
Time After: 0.01629 seconds
Time Before: 0.01169 seconds
Time After: 0.01653 seconds
Time Taken: 0.00484 seconds
Time Before: 0.02295 seconds
Time After: 0.02309 seconds
Time Before: 0.02519 seconds
Time After: 0.02640 seconds
End call of global.php: 0.028091907501221
Time Before: 0.02955 seconds
Time After: 0.02975 seconds
Time Before: 0.03246 seconds
Time After: 0.03470 seconds
Time Taken: 0.00224 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=14386'
Time Before: 0.04847 seconds
Time After: 0.04875 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.047386884689331 seconds with 9 queries, spending 0.0091848373413086 doing MySQL queries and 0.038202047348022 doing PHP things.
