Time Before: 0.00197 seconds
Time After: 0.00273 seconds
Time Taken: 0.00076 seconds
Time Before: 0.00283 seconds
Time After: 0.00331 seconds
Time Before: 0.00354 seconds
Time After: 0.00369 seconds
Time Before: 0.00459 seconds
Time After: 0.00700 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00376 seconds
Time After: 0.01199 seconds
Time Taken: 0.00823 seconds
Time Before: 0.01566 seconds
Time After: 0.01606 seconds
Time Before: 0.01861 seconds
Time After: 0.01989 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01473 seconds
Time After: 0.02021 seconds
Time Taken: 0.00548 seconds
Memory After: 2,261.703 KB
Time Before: 0.02772 seconds
Time After: 0.02788 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.03027 seconds
Time After: 0.03155 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03526 seconds
Time After: 0.03542 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03864 seconds
Time After: 0.04009 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=143942' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05603 seconds
Time After: 0.05665 seconds
Time Taken: 0.00062 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
