Time Before: 0.00218 seconds
Time After: 0.00304 seconds
Time Taken: 0.00085 seconds
Time Before: 0.00312 seconds
Time After: 0.00389 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00420 seconds
Time After: 0.00436 seconds
Time Before: 0.00522 seconds
Time After: 0.00799 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00443 seconds
Time After: 0.01142 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01319 seconds
Time After: 0.01357 seconds
Time Before: 0.01593 seconds
Time After: 0.01722 seconds
Time Before: 0.01260 seconds
Time After: 0.01743 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02380 seconds
Time After: 0.02423 seconds
Time Before: 0.02738 seconds
Time After: 0.02868 seconds
End call of global.php: 0.031719207763672
Time Before: 0.03380 seconds
Time After: 0.03401 seconds
Time Before: 0.03649 seconds
Time After: 0.03815 seconds
Time Taken: 0.00166 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=143958'
Time Before: 0.05269 seconds
Time After: 0.05360 seconds
Time Taken: 0.00091 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.051749229431152 seconds with 9 queries, spending 0.0098552703857422 doing MySQL queries and 0.04189395904541 doing PHP things.
