Time Before: 0.00879 seconds
Time After: 0.01164 seconds
Time Taken: 0.00285 seconds
Time Before: 0.01173 seconds
Time After: 0.01218 seconds
Time Before: 0.01243 seconds
Time After: 0.01259 seconds
Time Before: 0.01342 seconds
Time After: 0.01591 seconds
Time Taken: 0.00249 seconds
Time Before: 0.01267 seconds
Time After: 0.02031 seconds
Time Taken: 0.00764 seconds
Time Before: 0.02601 seconds
Time After: 0.02642 seconds
Time Before: 0.02906 seconds
Time After: 0.03025 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02536 seconds
Time After: 0.03052 seconds
Time Taken: 0.00516 seconds
Time Before: 0.04313 seconds
Time After: 0.04333 seconds
Time Before: 0.05344 seconds
Time After: 0.05474 seconds
End call of global.php: 0.057038068771362
Time Before: 0.06424 seconds
Time After: 0.06440 seconds
Time Before: 0.06685 seconds
Time After: 0.06835 seconds
SET lastactivity = 1785289493, location = '/forums/private.php?do=newpm&explain=1&u=144008'
Time Before: 0.08846 seconds
Time After: 0.08870 seconds
Page generated in 0.087532043457031 seconds with 9 queries, spending 0.0080873966217041 doing MySQL queries and 0.079444646835327 doing PHP things.
