Time Before: 0.00158 seconds
Time After: 0.00213 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00221 seconds
Time After: 0.00270 seconds
Time Before: 0.00300 seconds
Time After: 0.00317 seconds
Time Before: 0.00407 seconds
Time After: 0.00699 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00326 seconds
Time After: 0.01194 seconds
Time Taken: 0.00868 seconds
Time Before: 0.01472 seconds
Time After: 0.01521 seconds
Time Before: 0.01784 seconds
Time After: 0.01909 seconds
Time Before: 0.01386 seconds
Time After: 0.01934 seconds
Time Taken: 0.00549 seconds
Time Before: 0.02964 seconds
Time After: 0.03007 seconds
Time Before: 0.03209 seconds
Time After: 0.03351 seconds
Time Before: 0.03775 seconds
Time After: 0.03797 seconds
Time Before: 0.04064 seconds
Time After: 0.04214 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1783059456, location = '/forums/private.php?do=newpm&explain=1&u=144024' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.06033 seconds
Time After: 0.07167 seconds
Time Taken: 0.01134 seconds
