Time Before: 0.00142 seconds
Time After: 0.00213 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00223 seconds
Time After: 0.00288 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00308 seconds
Time After: 0.00319 seconds
Time Before: 0.00389 seconds
Time After: 0.00634 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00324 seconds
Time After: 0.00972 seconds
Time Taken: 0.00648 seconds
Time Before: 0.01165 seconds
Time After: 0.01205 seconds
Time Before: 0.01473 seconds
Time After: 0.01596 seconds
Time Before: 0.01099 seconds
Time After: 0.01613 seconds
Time Taken: 0.00514 seconds
Time Before: 0.02118 seconds
Time After: 0.02129 seconds
Time Before: 0.02421 seconds
Time After: 0.02549 seconds
End call of global.php: 0.027143955230713
Time Before: 0.02848 seconds
Time After: 0.02861 seconds
Time Before: 0.03064 seconds
Time After: 0.03208 seconds
SET lastactivity = 1780602408, location = '/forums/private.php?do=newpm&explain=1&u=144035', badlocation = 1
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04447 seconds
Time After: 0.04491 seconds
Page generated in 0.043558835983276 seconds with 9 queries, spending 0.0082416534423828 doing MySQL queries and 0.035317182540894 doing PHP things.
