Time Before: 0.01014 seconds
Time After: 0.01252 seconds
Time Taken: 0.00238 seconds
Time Before: 0.01259 seconds
Time After: 0.01293 seconds
Time Before: 0.01320 seconds
Time After: 0.01333 seconds
Time Before: 0.01388 seconds
Time After: 0.01614 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01337 seconds
Time After: 0.02052 seconds
Time Taken: 0.00715 seconds
Time Before: 0.02869 seconds
Time After: 0.02922 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03114 seconds
Time After: 0.03241 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02632 seconds
Time After: 0.03266 seconds
Time Taken: 0.00634 seconds
Memory After: 2,261.820 KB
Time Before: 0.05389 seconds
Time After: 0.05537 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.06394 seconds
Time After: 0.06521 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.067502975463867
Time Before: 0.07115 seconds
Time After: 0.07130 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.07359 seconds
Time After: 0.07532 seconds
Time Taken: 0.00172 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788985276, location = '/forums/private.php?do=newpm&explain=1&u=144041'
Time Before: 0.09256 seconds
Time After: 0.09277 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.091440200805664 seconds with 9 queries, spending 0.0093598365783691 doing MySQL queries and 0.082080364227295 doing PHP things.
