Time Before: 0.00159 seconds
Time After: 0.00245 seconds
Time Taken: 0.00087 seconds
Time Before: 0.00252 seconds
Time After: 0.00326 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00356 seconds
Time After: 0.00375 seconds
Time Before: 0.00460 seconds
Time After: 0.00709 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00382 seconds
Time After: 0.01048 seconds
Time Taken: 0.00666 seconds
Time Before: 0.01245 seconds
Time After: 0.01268 seconds
Time Before: 0.01620 seconds
Time After: 0.01741 seconds
Time Before: 0.01175 seconds
Time After: 0.01759 seconds
Time Taken: 0.00584 seconds
Time Before: 0.02267 seconds
Time After: 0.02282 seconds
Time Before: 0.02483 seconds
Time After: 0.02605 seconds
Time Before: 0.02909 seconds
Time After: 0.02924 seconds
Time Before: 0.03139 seconds
Time After: 0.03285 seconds
UPDATE session SET lastactivity = 1772826670, location = '/forums/private.php?do=newpm&explain=1&u=144083' WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.04552 seconds
Time After: 0.04583 seconds
