Time Before: 0.02000 seconds
Time After: 0.02863 seconds
Time Taken: 0.00863 seconds
Time Before: 0.02873 seconds
Time After: 0.02923 seconds
Time Before: 0.02945 seconds
Time After: 0.02957 seconds
Time Before: 0.03035 seconds
Time After: 0.03251 seconds
Time Taken: 0.00216 seconds
Time Before: 0.02964 seconds
Time After: 0.03701 seconds
Time Taken: 0.00738 seconds
Time Before: 0.04634 seconds
Time After: 0.04673 seconds
Time Before: 0.04929 seconds
Time After: 0.05052 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04558 seconds
Time After: 0.05077 seconds
Time Taken: 0.00519 seconds
Memory After: 2,261.703 KB
Time Before: 0.08199 seconds
Time After: 0.08212 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.10146 seconds
Time After: 0.10271 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.11759 seconds
Time After: 0.11785 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12030 seconds
Time After: 0.12193 seconds
Time Taken: 0.00163 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=144156', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.14035 seconds
Time After: 0.14060 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
