Time Before: 0.00975 seconds
Time After: 0.01296 seconds
Time Taken: 0.00321 seconds
Time Before: 0.01306 seconds
Time After: 0.01353 seconds
Time Before: 0.01379 seconds
Time After: 0.01395 seconds
Time Before: 0.01474 seconds
Time After: 0.01722 seconds
Time Taken: 0.00247 seconds
Time Before: 0.01403 seconds
Time After: 0.02137 seconds
Time Taken: 0.00734 seconds
Time Before: 0.02638 seconds
Time After: 0.02676 seconds
Time Before: 0.02933 seconds
Time After: 0.03052 seconds
Time Before: 0.02562 seconds
Time After: 0.03076 seconds
Time Taken: 0.00515 seconds
Time Before: 0.05845 seconds
Time After: 0.05858 seconds
Time Before: 0.06788 seconds
Time After: 0.06910 seconds
Time Before: 0.07504 seconds
Time After: 0.07520 seconds
Time Before: 0.07839 seconds
Time After: 0.07984 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=144171', badlocation = 1 WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.09854 seconds
Time After: 0.10560 seconds
Time Taken: 0.00706 seconds
