Time Before: 0.00998 seconds
Time After: 0.01511 seconds
Time Taken: 0.00513 seconds
Time Before: 0.01522 seconds
Time After: 0.01563 seconds
Time Before: 0.01587 seconds
Time After: 0.01602 seconds
Time Before: 0.01681 seconds
Time After: 0.02001 seconds
Time Taken: 0.00320 seconds
Time Before: 0.01610 seconds
Time After: 0.02567 seconds
Time Taken: 0.00957 seconds
Time Before: 0.03163 seconds
Time After: 0.03199 seconds
Time Before: 0.03462 seconds
Time After: 0.03582 seconds
Time Before: 0.03074 seconds
Time After: 0.03605 seconds
Time Taken: 0.00530 seconds
Time Before: 0.06161 seconds
Time After: 0.06177 seconds
Time Before: 0.07524 seconds
Time After: 0.07649 seconds
End call of global.php: 0.078770160675049
Time Before: 0.08291 seconds
Time After: 0.08307 seconds
Time Before: 0.08581 seconds
Time After: 0.08726 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=144180', badlocation = 1
WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.10444 seconds
Time After: 0.10474 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
Page generated in 0.10350918769836 seconds with 9 queries, spending 0.0086443424224854 doing MySQL queries and 0.094864845275879 doing PHP things.
