Time Before: 0.00188 seconds
Time After: 0.00242 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00251 seconds
Time After: 0.00287 seconds
Time Before: 0.00309 seconds
Time After: 0.00320 seconds
Time Before: 0.00403 seconds
Time After: 0.00707 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00327 seconds
Time After: 0.01165 seconds
Time Taken: 0.00838 seconds
Time Before: 0.01474 seconds
Time After: 0.01510 seconds
Time Before: 0.01764 seconds
Time After: 0.01886 seconds
Time Before: 0.01416 seconds
Time After: 0.01913 seconds
Time Taken: 0.00497 seconds
Time Before: 0.02659 seconds
Time After: 0.02673 seconds
Time Before: 0.02933 seconds
Time After: 0.03065 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03546 seconds
Time After: 0.03563 seconds
Time Before: 0.03854 seconds
Time After: 0.04009 seconds
Time Taken: 0.00155 seconds
UPDATE session SET lastactivity = 1768780386, location = '/forums/private.php?do=newpm&explain=1&u=144188', badlocation = 1 WHERE sessionhash = '493329e92668bdfe23f60c8f4163b3e0'
Time Before: 0.05486 seconds
Time After: 0.05510 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
