Time Before: 0.00245 seconds
Time After: 0.00297 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00305 seconds
Time After: 0.00380 seconds
Time Taken: 0.00075 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00411 seconds
Time After: 0.00429 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00496 seconds
Time After: 0.00758 seconds
Time Taken: 0.00262 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00435 seconds
Time After: 0.01097 seconds
Time Taken: 0.00662 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01310 seconds
Time After: 0.01352 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01587 seconds
Time After: 0.01709 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01246 seconds
Time After: 0.01728 seconds
Time Taken: 0.00482 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02382 seconds
Time After: 0.02412 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.03127 seconds
Time After: 0.03261 seconds
Time Taken: 0.00134 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.034330129623413
Time Before: 0.04049 seconds
Time After: 0.04069 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.04273 seconds
Time After: 0.04420 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772918509, location = '/forums/private.php?do=newpm&explain=1&u=144201'
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.05738 seconds
Time After: 0.05771 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
Page generated in 0.056483030319214 seconds with 9 queries, spending 0.0088300704956055 doing MySQL queries and 0.047652959823608 doing PHP things.
