Time Before: 0.01954 seconds
Time After: 0.02566 seconds
Time Taken: 0.00612 seconds
Time Before: 0.02576 seconds
Time After: 0.02631 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02661 seconds
Time After: 0.02673 seconds
Time Before: 0.02750 seconds
Time After: 0.02978 seconds
Time Taken: 0.00229 seconds
Time Before: 0.02681 seconds
Time After: 0.03385 seconds
Time Taken: 0.00705 seconds
Time Before: 0.04368 seconds
Time After: 0.04432 seconds
Time Taken: 0.00064 seconds
Time Before: 0.04640 seconds
Time After: 0.04897 seconds
Time Taken: 0.00257 seconds
Time Before: 0.04283 seconds
Time After: 0.04920 seconds
Time Taken: 0.00637 seconds
Time Before: 0.07342 seconds
Time After: 0.07356 seconds
Time Before: 0.33446 seconds
Time After: 0.33589 seconds
End call of global.php: 0.33804893493652
Time Before: 0.34216 seconds
Time After: 0.34234 seconds
Time Before: 0.34473 seconds
Time After: 0.34623 seconds
SET lastactivity = 1782872520, location = '/forums/private.php?do=newpm&explain=1&u=144266', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.36174 seconds
Time After: 0.36204 seconds
Page generated in 0.36064100265503 seconds with 9 queries, spending 0.0096919536590576 doing MySQL queries and 0.35094904899597 doing PHP things.
