Time Before: 0.02778 seconds
Time After: 0.04050 seconds
Time Taken: 0.01272 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.04064 seconds
Time After: 0.04103 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.04130 seconds
Time After: 0.04144 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.04234 seconds
Time After: 0.04473 seconds
Time Taken: 0.00239 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.04152 seconds
Time After: 0.04925 seconds
Time Taken: 0.00773 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.06553 seconds
Time After: 0.06573 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.06826 seconds
Time After: 0.06942 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.06480 seconds
Time After: 0.06969 seconds
Time Taken: 0.00489 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.12306 seconds
Time After: 0.12321 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.34306 seconds
Time After: 0.34428 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
End call of global.php: 0.34674000740051
Time Before: 0.37686 seconds
Time After: 0.37706 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.38673 seconds
Time After: 0.38818 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
SET lastactivity = 1772566477, location = '/forums/private.php?do=newpm&explain=1&u=14431', badlocation = 1
WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.42218 seconds
Time After: 0.42244 seconds
Memory Before: 5,998.055 KB
Memory After: 5,998.250 KB
Memory Used: 0.195 KB
Page generated in 0.42076086997986 seconds with 9 queries, spending 0.0075597763061523 doing MySQL queries and 0.41320109367371 doing PHP things.
