Time Before: 0.00144 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00264 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00292 seconds
Time After: 0.00305 seconds
Time Before: 0.00371 seconds
Time After: 0.00662 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00310 seconds
Time After: 0.01002 seconds
Time Taken: 0.00691 seconds
Time Before: 0.01177 seconds
Time After: 0.01219 seconds
Time Before: 0.01464 seconds
Time After: 0.01591 seconds
Time Before: 0.01119 seconds
Time After: 0.01608 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02105 seconds
Time After: 0.02119 seconds
Time Before: 0.02307 seconds
Time After: 0.02430 seconds
Time Before: 0.02721 seconds
Time After: 0.02739 seconds
Time Before: 0.02938 seconds
Time After: 0.03082 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=144320' WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.04368 seconds
Time After: 0.04398 seconds
