Time Before: 0.00163 seconds
Time After: 0.00211 seconds
Time Before: 0.00218 seconds
Time After: 0.00255 seconds
Time Before: 0.00279 seconds
Time After: 0.00297 seconds
Time Before: 0.00370 seconds
Time After: 0.00582 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00301 seconds
Time After: 0.00931 seconds
Time Taken: 0.00630 seconds
Time Before: 0.01122 seconds
Time After: 0.01163 seconds
Time Before: 0.01336 seconds
Time After: 0.01453 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01054 seconds
Time After: 0.01470 seconds
Time Taken: 0.00416 seconds
Time Before: 0.02087 seconds
Time After: 0.02101 seconds
Time Before: 0.02320 seconds
Time After: 0.02442 seconds
End call of global.php: 0.026095867156982
Time Before: 0.02742 seconds
Time After: 0.02756 seconds
Time Before: 0.03017 seconds
Time After: 0.03162 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=144327', badlocation = 1
Time Before: 0.04686 seconds
Time After: 0.04717 seconds
Page generated in 0.045639991760254 seconds with 9 queries, spending 0.0075068473815918 doing MySQL queries and 0.038133144378662 doing PHP things.
