Time Before: 0.01131 seconds
Time After: 0.01450 seconds
Time Taken: 0.00320 seconds
Time Before: 0.01460 seconds
Time After: 0.01501 seconds
Time Before: 0.01522 seconds
Time After: 0.01538 seconds
Time Before: 0.01643 seconds
Time After: 0.02001 seconds
Time Taken: 0.00358 seconds
Time Before: 0.01549 seconds
Time After: 0.02517 seconds
Time Taken: 0.00968 seconds
Time Before: 0.02993 seconds
Time After: 0.03034 seconds
Time Before: 0.03314 seconds
Time After: 0.03430 seconds
Time Taken: 0.00116 seconds
Time Before: 0.02932 seconds
Time After: 0.03454 seconds
Time Taken: 0.00522 seconds
Time Before: 0.05144 seconds
Time After: 0.05160 seconds
Time Before: 0.06368 seconds
Time After: 0.06520 seconds
Time Taken: 0.00152 seconds
End call of global.php: 0.06757116317749
Time Before: 0.07385 seconds
Time After: 0.07399 seconds
Time Before: 0.07684 seconds
Time After: 0.07826 seconds
SET lastactivity = 1789121514, location = '/forums/private.php?do=newpm&explain=1&u=144334'
Time Before: 0.09407 seconds
Time After: 0.09435 seconds
Page generated in 0.093060970306396 seconds with 9 queries, spending 0.0092380046844482 doing MySQL queries and 0.083822965621948 doing PHP things.
