Time Before: 0.00257 seconds
Time After: 0.00319 seconds
Time Taken: 0.00063 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00335 seconds
Time After: 0.00414 seconds
Time Taken: 0.00080 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00443 seconds
Time After: 0.00459 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00541 seconds
Time After: 0.00834 seconds
Time Taken: 0.00293 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00468 seconds
Time After: 0.01204 seconds
Time Taken: 0.00737 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01414 seconds
Time After: 0.01452 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01710 seconds
Time After: 0.02023 seconds
Time Taken: 0.00314 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01340 seconds
Time After: 0.02047 seconds
Time Taken: 0.00707 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.02868 seconds
Time After: 0.02881 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.03584 seconds
Time After: 0.03714 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.04783 seconds
Time After: 0.04840 seconds
Time Taken: 0.00057 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.05105 seconds
Time After: 0.05323 seconds
Time Taken: 0.00218 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1768944647, location = '/forums/private.php?do=newpm&explain=1&u=144421', badlocation = 1 WHERE sessionhash = '498d073752497ccaba409783e9267bef'
Time Before: 0.06832 seconds
Time After: 0.06855 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
