Time Before: 0.00166 seconds
Time After: 0.00218 seconds
Time Before: 0.00224 seconds
Time After: 0.00294 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00332 seconds
Time After: 0.00353 seconds
Time Before: 0.00420 seconds
Time After: 0.00670 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00360 seconds
Time After: 0.01014 seconds
Time Taken: 0.00655 seconds
Time Before: 0.01193 seconds
Time After: 0.01211 seconds
Time Before: 0.01363 seconds
Time After: 0.01485 seconds
Time Before: 0.01133 seconds
Time After: 0.01503 seconds
Time Taken: 0.00370 seconds
Time Before: 0.02035 seconds
Time After: 0.02048 seconds
Time Before: 0.02240 seconds
Time After: 0.02363 seconds
Time Before: 0.02673 seconds
Time After: 0.02689 seconds
Time Before: 0.02892 seconds
Time After: 0.03035 seconds
UPDATE session SET lastactivity = 1784870402, location = '/forums/private.php?do=newpm&explain=1&u=144426', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04330 seconds
Time After: 0.04358 seconds
