Time Before: 0.00214 seconds
Time After: 0.00281 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00291 seconds
Time After: 0.00338 seconds
Time Before: 0.00367 seconds
Time After: 0.00383 seconds
Time Before: 0.00463 seconds
Time After: 0.00743 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00388 seconds
Time After: 0.01087 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01311 seconds
Time After: 0.01391 seconds
Time Taken: 0.00079 seconds
Time Before: 0.01621 seconds
Time After: 0.01746 seconds
Time Before: 0.01215 seconds
Time After: 0.01763 seconds
Time Taken: 0.00548 seconds
Time Before: 0.02505 seconds
Time After: 0.02522 seconds
Time Before: 0.02724 seconds
Time After: 0.02848 seconds
End call of global.php: 0.030130863189697
Time Before: 0.03154 seconds
Time After: 0.03168 seconds
Time Before: 0.03369 seconds
Time After: 0.03528 seconds
Time Taken: 0.00159 seconds
SET lastactivity = 1777096667, location = '/forums/private.php?do=newpm&explain=1&u=144446', badlocation = 1
WHERE sessionhash = '7775e95b18bef93607bc556467059588'
Time Before: 0.04985 seconds
Time After: 0.05021 seconds
Page generated in 0.048902988433838 seconds with 9 queries, spending 0.0089819431304932 doing MySQL queries and 0.039921045303345 doing PHP things.
