Time Before: 0.01595 seconds
Time After: 0.02324 seconds
Time Taken: 0.00729 seconds
Time Before: 0.02334 seconds
Time After: 0.02384 seconds
Time Before: 0.02411 seconds
Time After: 0.02422 seconds
Time Before: 0.02498 seconds
Time After: 0.02744 seconds
Time Taken: 0.00245 seconds
Time Before: 0.02427 seconds
Time After: 0.03152 seconds
Time Taken: 0.00724 seconds
Time Before: 0.03749 seconds
Time After: 0.03785 seconds
Time Before: 0.04021 seconds
Time After: 0.04138 seconds
Time Taken: 0.00117 seconds
Time Before: 0.03675 seconds
Time After: 0.04165 seconds
Time Taken: 0.00490 seconds
Time Before: 0.06819 seconds
Time After: 0.06835 seconds
Time Before: 0.07876 seconds
Time After: 0.07997 seconds
End call of global.php: 0.081867218017578
Time Before: 0.08661 seconds
Time After: 0.08677 seconds
Time Before: 0.08935 seconds
Time After: 0.09079 seconds
SET lastactivity = 1776723734, location = '/forums/private.php?do=newpm&explain=1&u=144461', badlocation = 1
Time Before: 0.10811 seconds
Time After: 0.10837 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.10684204101562 seconds with 9 queries, spending 0.0078186988830566 doing MySQL queries and 0.099023342132568 doing PHP things.
