Time Before: 0.00158 seconds
Time After: 0.00208 seconds
Time Before: 0.00215 seconds
Time After: 0.00275 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00303 seconds
Time After: 0.00315 seconds
Time Before: 0.00392 seconds
Time After: 0.00625 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00321 seconds
Time After: 0.00972 seconds
Time Taken: 0.00651 seconds
Time Before: 0.01163 seconds
Time After: 0.01217 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01378 seconds
Time After: 0.01502 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01097 seconds
Time After: 0.01519 seconds
Time Taken: 0.00422 seconds
Memory After: 2,261.703 KB
Time Before: 0.01999 seconds
Time After: 0.02018 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02196 seconds
Time After: 0.02317 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.024760007858276
Time Before: 0.02616 seconds
Time After: 0.02634 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.02841 seconds
Time After: 0.02985 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=144465'
Time Before: 0.04203 seconds
Time After: 0.04232 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.041162967681885 seconds with 9 queries, spending 0.0081462860107422 doing MySQL queries and 0.033016681671143 doing PHP things.
