Time Before: 0.01093 seconds
Time After: 0.01438 seconds
Time Taken: 0.00346 seconds
Time Before: 0.01450 seconds
Time After: 0.01501 seconds
Time Before: 0.01532 seconds
Time After: 0.01550 seconds
Time Before: 0.01637 seconds
Time After: 0.01889 seconds
Time Taken: 0.00251 seconds
Time Before: 0.01557 seconds
Time After: 0.02344 seconds
Time Taken: 0.00787 seconds
Time Before: 0.02822 seconds
Time After: 0.02868 seconds
Time Before: 0.03162 seconds
Time After: 0.03284 seconds
Time Before: 0.02755 seconds
Time After: 0.03306 seconds
Time Taken: 0.00550 seconds
Time Before: 0.04815 seconds
Time After: 0.04832 seconds
Time Before: 0.05841 seconds
Time After: 0.05963 seconds
Time Before: 0.06555 seconds
Time After: 0.06572 seconds
Time Before: 0.06804 seconds
Time After: 0.06947 seconds
UPDATE session SET lastactivity = 1782939907, location = '/forums/private.php?do=newpm&explain=1&u=14452', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.08436 seconds
Time After: 0.08462 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
