Time Before: 0.00197 seconds
Time After: 0.00322 seconds
Time Before: 0.00330 seconds
Time After: 0.00427 seconds
Time Taken: 0.00098 seconds
Time Before: 0.00464 seconds
Time After: 0.00480 seconds
Time Before: 0.00554 seconds
Time After: 0.00797 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00486 seconds
Time After: 0.01138 seconds
Time Taken: 0.00652 seconds
Time Before: 0.01372 seconds
Time After: 0.01403 seconds
Time Before: 0.01650 seconds
Time After: 0.01776 seconds
Time Before: 0.01306 seconds
Time After: 0.01795 seconds
Time Taken: 0.00489 seconds
Memory After: 2,885.227 KB
Memory Used: 132.898 KB
Time Before: 0.02388 seconds
Time After: 0.02416 seconds
Memory Before: 3,438.344 KB
Memory After: 3,438.859 KB
Time Before: 0.02626 seconds
Time After: 0.02757 seconds
Memory Before: 3,526.039 KB
Memory After: 3,526.633 KB
End call of global.php: 0.029345035552979
Time Before: 0.03096 seconds
Time After: 0.03119 seconds
Memory Before: 4,163.938 KB
Memory After: 4,164.367 KB
Time Before: 0.03336 seconds
Time After: 0.03489 seconds
Time Taken: 0.00153 seconds
Memory Before: 4,445.500 KB
Memory After: 4,447.188 KB
SET lastactivity = 1784874794, location = '/forums/private.php?do=newpm&explain=1&u=144523'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04766 seconds
Time After: 0.04796 seconds
Memory Before: 4,911.156 KB
Memory After: 4,911.383 KB
Page generated in 0.046639919281006 seconds with 9 queries, spending 0.0087869167327881 doing MySQL queries and 0.037853002548218 doing PHP things.
