Time Before: 0.00138 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00256 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00280 seconds
Time After: 0.00291 seconds
Time Before: 0.00364 seconds
Time After: 0.00700 seconds
Time Taken: 0.00335 seconds
Time Before: 0.00295 seconds
Time After: 0.01165 seconds
Time Taken: 0.00869 seconds
Time Before: 0.01430 seconds
Time After: 0.01476 seconds
Time Before: 0.01719 seconds
Time After: 0.01838 seconds
Time Before: 0.01350 seconds
Time After: 0.01858 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02368 seconds
Time After: 0.02385 seconds
Time Before: 0.02562 seconds
Time After: 0.02692 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.028775930404663
Time Before: 0.03000 seconds
Time After: 0.03018 seconds
Time Before: 0.03250 seconds
Time After: 0.03398 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=144528'
Time Before: 0.04697 seconds
Time After: 0.04726 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.046082973480225 seconds with 9 queries, spending 0.0091781616210938 doing MySQL queries and 0.036904811859131 doing PHP things.
