Time Before: 0.00346 seconds
Time After: 0.00483 seconds
Time Taken: 0.00137 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00492 seconds
Time After: 0.00532 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00553 seconds
Time After: 0.00567 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00640 seconds
Time After: 0.00897 seconds
Time Taken: 0.00257 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00572 seconds
Time After: 0.01238 seconds
Time Taken: 0.00666 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01478 seconds
Time After: 0.01530 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01885 seconds
Time After: 0.02019 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01411 seconds
Time After: 0.02036 seconds
Time Taken: 0.00625 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02742 seconds
Time After: 0.02755 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.03071 seconds
Time After: 0.03252 seconds
Time Taken: 0.00181 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.034231901168823
Time Before: 0.03560 seconds
Time After: 0.03574 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03786 seconds
Time After: 0.03939 seconds
Time Taken: 0.00153 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=144543'
Time Before: 0.05227 seconds
Time After: 0.05255 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
Page generated in 0.051389932632446 seconds with 9 queries, spending 0.0088560581207275 doing MySQL queries and 0.042533874511719 doing PHP things.
