Time Before: 0.01039 seconds
Time After: 0.01362 seconds
Time Taken: 0.00323 seconds
Time Before: 0.01373 seconds
Time After: 0.01438 seconds
Time Taken: 0.00065 seconds
Time Before: 0.01473 seconds
Time After: 0.01498 seconds
Time Before: 0.01572 seconds
Time After: 0.01851 seconds
Time Taken: 0.00279 seconds
Time Before: 0.01506 seconds
Time After: 0.02223 seconds
Time Taken: 0.00717 seconds
Time Before: 0.02717 seconds
Time After: 0.02756 seconds
Time Before: 0.03037 seconds
Time After: 0.03163 seconds
Time Before: 0.02655 seconds
Time After: 0.03184 seconds
Time Taken: 0.00529 seconds
Time Before: 0.04588 seconds
Time After: 0.04605 seconds
Time Before: 0.05309 seconds
Time After: 0.05435 seconds
End call of global.php: 0.056634902954102
Time Before: 0.05973 seconds
Time After: 0.05992 seconds
Time Before: 0.06230 seconds
Time After: 0.06377 seconds
SET lastactivity = 1784731602, location = '/forums/private.php?do=newpm&explain=1&u=144560'
Time Before: 0.08179 seconds
Time After: 0.08218 seconds
Page generated in 0.080182790756226 seconds with 9 queries, spending 0.0088322162628174 doing MySQL queries and 0.071350574493408 doing PHP things.
