Time Before: 0.02442 seconds
Time After: 0.04200 seconds
Time Taken: 0.01758 seconds
Time Before: 0.04209 seconds
Time After: 0.04259 seconds
Time Before: 0.04290 seconds
Time After: 0.04307 seconds
Time Before: 0.04382 seconds
Time After: 0.04684 seconds
Time Taken: 0.00303 seconds
Time Before: 0.04312 seconds
Time After: 0.05112 seconds
Time Taken: 0.00799 seconds
Time Before: 0.06236 seconds
Time After: 0.06290 seconds
Time Taken: 0.00053 seconds
Time Before: 0.06451 seconds
Time After: 0.06698 seconds
Time Taken: 0.00247 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.06136 seconds
Time After: 0.06723 seconds
Time Taken: 0.00586 seconds
Memory After: 2,261.820 KB
Time Before: 0.11993 seconds
Time After: 0.12010 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.28440 seconds
Time After: 0.28572 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.29701 seconds
Time After: 0.29722 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.29997 seconds
Time After: 0.30145 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789147421, location = '/forums/private.php?do=newpm&explain=1&u=144565', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.32048 seconds
Time After: 0.32077 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
